First post here: hello, hi, howdy!
I have a script which is designed to give the coordinates for solar system objects, but it outputs based on a coordinate system which has the Z-axis running parallel to Earth’s tilt and I’d like to use the ecliptic coordinate system. Now I programmed in a function to rotate the coordinates, but I’m assuming there’s a functionality similar to this built into Astropy and I may have missed it. Here is my code:
# Import
from astropy.coordinates import solar_system_ephemeris, get_body_barycentric, ICRS, PrecessedGeocentric
# Set Variables
start_date = '2023-12-25 00:00:00'
target_body = 'earth'
target_step_unit = 'day'
target_duration = 72
target_step_size = 6
cap = True
# Get Positions Function
def get_positions(body, start, duration, step_size, step_unit, if_cap):
# Reformat Start Time
start_time = Time(start, scale='tdb')
# Time Mapping
unit_mapping = {
'second': u.second,
'minute': u.minute,
'hour': u.hour,
'day': u.day,
'week': u.week,
'year': u.year,
'year_sidereal': 365.25636 * u.day
# Set Steps and Duration
step_duration = step_size * unit_mapping[step_unit]
total_duration = duration * unit_mapping[step_unit]
num_steps = int(total_duration / step_duration) + (1 if if_cap else 0)
# Initialize Array
positions = []
# Set the Ephemeris to Heliocentric
with solar_system_ephemeris.set('builtin'):
for step in range(num_steps):
# Calculate Current Step Time
current_time = start_time + step * step_duration
# Get Body Position - Heliocentric Frame
body_position = get_body_barycentric(body, current_time)
# Extract the XYZ Coordinates
xyz_km = np.array([body_position.x.to(u.km).value,
body_position.y.to(u.km).value,
body_position.z.to(u.km).value])
# Rotate the Coordinate System (Earth Tilt)
xyz_rotated = rotate_coordinates(xyz_km, -23.4393)
x_rotated, y_rotated, z_rotated = [u.Quantity(coord, unit=u.km) for coord in xyz_rotated]
# Append the rotated position as a tuple
positions.append((current_time, (x_rotated, y_rotated, z_rotated)))
return positions
# Rotate System Function
def rotate_coordinates(coords, angle_deg):
# Convert Degrees to Radians
angle_rad = np.radians(angle_deg)
# Rotation Matrix Around the X-axis
rotation_matrix = np.array([
[1, 0, 0],
[0, np.cos(angle_rad), -np.sin(angle_rad)],
[0, np.sin(angle_rad), np.cos(angle_rad)]
# Apply the Rotation
return np.dot(rotation_matrix, coords)
# Run: Retrieve Positions
target_positions = get_positions(
target_body,
start_date,
target_duration,
target_step_size,
target_step_unit,
cap)
# Rounding and Display
for time, pos in target_positions:
x = f"{pos[0].value:.2f}"
y = f"{pos[1].value:.2f}"
z = f"{pos[2].value:.2f}"
print(f"Time: {time.iso}, X: {x} km, Y: {y} km, Z: {z} km")
Thank you!
