Hi Astropy community,
I’ve been working with a few astronomical catalogs on a project that involves 3D visualization. I want to get the XYZ coordinates of stars and I’m typically working with either or both ICRS and/or Galactic coordinates.
To transform from the ICRS or Galactic frame to Cartesian, I create a Skycoord object and feed it arrays of data as shown in the code below. ‘data’ is a Pandas DataFrame which contains the data in my catalog.
import astropy.coordinates
#transform from ICRS to Cartesian XYZ
icrs_coords = astropy.coordinates.SkyCoord(
ra=list(data['RA_ICRS'])*u.deg,
dec=list(data['DE_ICRS'])*u.deg,
distance=list(data['dist_pc'])*u.pc,
frame='icrs'
data['x'] = icrs_coords.cartesian.x.value
data['y'] = icrs_coords.cartesian.y.value
data['z'] = icrs_coords.cartesian.z.value
#Transform from Galactic to Cartesian XYZ
galactic_coords = astropy.coordinates.SkyCoord(
l=list(data['GLon'])*u.deg,
b=list(data['GLat'])*u.deg,
frame='galactic'
data['gx'] = galactic_coords.cartesian.x.value
data['gy'] = galactic_coords.cartesian.y.value
data['gz'] = galactic_coords.cartesian.z.value
I expect this to work the same way if I want to go from ICRS to Cartesian or from Galactic to Cartesian, but I notice a distinct difference if I try both ways. Most commonly, I notice that the ICRS to Cartesian transform is rotated about 120 degrees counter-clockwise if i look in the XZ plane. Sometimes, the plots simply look remarkably different. I’ve included two plots generated from my catalogs to demonstrate this. Based on intuition of what the catalogs’ distributions should look like, it looks as if the Galactic to Cartesian transform is working correctly, but the ICRS to Cartesian transform is not. Does anyone know if I’m doing anything wrong or why this is?
Extra context: I’ve done some digging and confirmed that when I transform from ICRS to galactic or vice versa, the resulting coordinates are always approximately equal to those native in the catalog. The galactic coordinates I obtain from a Skycoord object which was given the ICRS coordinates are the same as the galactic coordinates in the catalog, and vice versa. Despite this, the Skycoord object seems to spit out different Cartesian coordinates depending on if it is given RA/Dec versus GLon and GLat.
