Hi all ,
I am using astropy package for converting RA, Dec and distance ( Line of Sight) to Galactocentric coordinates. The problem is the following:
I generated a sphere of randomly distributed 1 million points in RA , Dec and distance plot. It is like a synthetic cluster located at 4000 pc and having radius of 1 pc. Now when converted to Galactocentric frame, I am getting all points flattened to an ellipse. I intuitively expected it to still remain a sphere, as we are just looking from a different location , thus a sphere should, remain a sphere. Is this output expected , or am I doing something wrong ? Following is the code and corresponding output:
from astropy.io.votable import parse, writeto
from astropy.table import Table, Column
from astropy.coordinates import SkyCoord, Galactic, CartesianRepresentation
from astropy import units as uGenerating Synthetic Cluster in ICRS
Center coordinates
center_ra = 343.81252 # degrees
center_dec = 62.53608 # degrees
center_distance = 4000 # parsecsNumber of stars
num_stars = 10**6
Radius of the sphere
radius = 1 # this is in pc
distances = (np.random.uniform(0, 1, num_stars))**(1/3) * radius
Generating random spherical coordinates
theta = np.random.uniform(0, 2*np.pi, num_stars)
phi = np.arccos(2 * np.random.uniform(0, 1, num_stars) - 1)Converting spherical coordinates to Cartesian coordinates
ra = center_ra + np.arctan(distances * np.sin(phi) * np.cos(theta)/center_distance)
dec = center_dec + np.arctan(distances * np.sin(phi) * np.sin(theta)/center_distance)
distance = center_distance + distances * np.cos(phi)Creating a FITS table with the generated data (RA, Dec and Distance)
hdu = fits.BinTableHDU.from_columns([
fits.Column(name=‘RA’, format=‘D’, array=ra),
fits.Column(name=‘Dec’, format=‘D’, array=dec), This text will be hidden
fits.Column(name=‘Distance’, format=‘D’, array=distance)
])Save the FITS table to a file
hdu.writeto(‘synthetic_star_cluster.fits’, overwrite=True)
Output in RA, Dec and Distance plot is as expected ( a perfect spherical synthetic cluster, refer the figure at the end.)
Now I am reading this fits file to convert coordinates to galactocentric frame :
import astropy.coordinates as coordfits_data = fits.getdata(‘synthetic_star_cluster.fits’)
table = Table(fits_data)Extracting data from the loaded data array
ra = table[‘RA’]
dec = table[‘Dec’]
distance = table[‘Distance’]c = coord.SkyCoord(ra=ra * u.degree,
dec=dec * u.degree,
distance=(distance) * u.pc,
frame=‘icrs’)
galactocentric_cartesian = c.transform_to(coord.Galactocentric(galcen_distance =8.3 * u.kpc, z_sun =27 * u.pc))Define new columns for galactocentric coordinates
X_column = Column(data=galactocentric_cartesian.x.value, name=‘X’, dtype=‘float64’)
Y_column = Column(data=galactocentric_cartesian.y.value, name=‘Y’, dtype=‘float64’)
Z_column = Column(data=galactocentric_cartesian.z.value, name=‘Z’, dtype=‘float64’)Append the new column to the table
table.add_column(X_column)
table.add_column(Y_column)
table.add_column(Z_column)Write the modified Astropy Table to a FITS file
table.write(‘synthetic_XYZ_out’, format=‘fits’, overwrite=True)
The figure below clearly shows that a spherical synthetic cluster in ICRS frame is a flattened ellipse in galactocentric frame , shouldn’t it remain a sphere? . Why is this happening?
