I am confused with the installation. Just installed Sunpy on a Windows machine with conda. I did conda install -c conda-forge sunpy but when doing a sunpy.map.whatever I got the error that sunpy has no attribute map. Then I see on the installation info that for a pip installation, we do need to explicitly include dependencies, as you show above with all. Is that needed with conda too? If not, any idea why i’m missing the map attribute after a conda install?
