Cross-matching 2 catalogs
Dear all
I want to cross-match two catalogs. But the Dec and RA coordinate data of these two catalogs are written as “h m s” and “d m s” (instead of being separated by a “:” a space separates them).
RAJ2000
00 32 41.56
00 32 41.55
That’s why I think my code gives an error.
*"TypeError: unsupported operand type(s) for : ‘MaskedColumn’ and ‘Unit’"
Is there a command where I can either add all the coordinates in degrees to my tables, or add colons between the given coordinates?
‌Best regards.
Hamid
You should be able to do this to construct a SkyCoord instance:
RA = ['00 32 41.56', '00 32 41.55']
Dec = ['12 34 56.78', '23 45 27.78']
c = coord.SkyCoord(RA, Dec, unit=(u.hourangle, u.degree))
(replace RA, Dec with your column data)
