Hello Astropy community,
I need your help with an error I have been receiving while trying to obtain the sky coordinates using astropy module in python.
The code looks like the following,
c = coord.SkyCoord(ra = u.Quantity(gaia_data["ra"] * u.deg),
dec = u.Quantity(gaia_data["dec"] * u.deg),
distance = u.Quantity(gaia_data["distance"] * u.pc),
pm_ra_cosdec = u.Quantity(gaia_data["pmra"] * u.mas/u.year),
pm_dec = u.Quantity(gaia_data["pmdec"] * u.mas/u.year),
radial_velocity = u.Quantity(gaia_data["rv"] * u.km/u.s))
I have read the queried data from Gaia DR3 into a pandas dataframe which is why I am converting the individual columns to quantity to ensure correctness while calculating the coordinates. The thing that surprises me the most is that the code works perfectly fine when I run it on a smaller dataset from Gaia DR3 (about 40k objects), the error pops up when I try doing it for the actual dataset (about 2.1M stars). So, may be the actual dataset has some stray data though that is unlikely because I have queried the database in such a way that the positional data does not have null values.
The error message looks like the following,
ValueError Traceback (most recent call last)
<ipython-input-17-e9a930de875e> in <module>
4 pm_ra_cosdec = u.Quantity(gaia_data["pmra"] * u.mas/u.year),
5 pm_dec = u.Quantity(gaia_data["pmdec"] * u.mas/u.year),
----> 6 radial_velocity = u.Quantity(gaia_data["rv"] * u.km/u.s))
~/.local/lib/python3.6/site-packages/astropy/coordinates/sky_coordinate.py in __init__(self, copy, *args, **kwargs)
329 # Finally make the internal coordinate object.
330 frame_kwargs.update(components)
--> 331 self._sky_coord_frame = frame_cls(copy=copy, **frame_kwargs)
332
333 if not self._sky_coord_frame.has_data:
~/.local/lib/python3.6/site-packages/astropy/coordinates/baseframe.py in __init__(self, copy, representation_type, differential_type, *args, **kwargs)
581 if not current_diff_unit.is_equivalent(current_repr_unit / u.s):
582 raise ValueError(
--> 583 "Differential data units are not compatible with"
584 "time-derivative of representation data units")
585 self._data = representation_data.with_differentials(
ValueError: Differential data units are not compatible withtime-derivative of representation data units
I do not understand the error message and I did not find any relevant source explaining what this means and how do I get rid of it?
Did anyone encounter this before? What is the solution?
