Hi everyone,
I’m noticing some strange behaviour when using apply_space_motion to a SkyCoord. First of all, it doesn’t only return a new SC, but the original SC gets altered, which is surprising. And when I try to run it again, it fails with an error message which I can’t quite parse. I’ve created a minimal viable example, posted below. This occurs both with Astropy 5.0.2, and 5.3.4.
import astropy
print('Version:', astropy.__version__)
T = Time([2020, 2021, 2021], format = 'decimalyear')
SC = SkyCoord(15 * u.deg, 15 * u.deg,
pm_ra_cosdec = 750 * u.mas/u.year, pm_dec = -200 * u.mas/u.year,
distance = 21 * u.pc, obstime = T[0])
print('Original SC:')
print(SC)
SC1 = SC.apply_space_motion(new_obstime = T[1])
print('Original SC, now mysteriously has a radial velocity added')
print(SC)
print('New SC, looks fine')
print(SC1)
# This second call to apply_space_motion fails
print('Now calling SC.apply_space_motion again...')
SC2 = SC.apply_space_motion(new_obstime = T[2])
The output including error message stack is:
Astropy Version: 5.3.4
Original SC:
<SkyCoord (ICRS): (ra, dec, distance) in (deg, deg, pc)
(15., 15., 21.)
(pm_ra_cosdec, pm_dec) in mas / yr
(750., -200.)>
Original SC, now mysteriously has a radial velocity added:
(15., 15., 21.)
(pm_ra_cosdec, pm_dec, radial_velocity) in (mas / yr, mas / yr, km / s)
(750., -200., -1.07785819e-15)>
New SC, looks fine:
(15.00021613, 14.99994433, 20.99999999)
(749.99980473, -200.00073221, 0.00029138)>
Traceback (most recent call last):
File "/home/boven/./SC-bug.py", line 24, in <module>
File "/home/boven/venv/apy/lib/python3.10/site-packages/astropy/coordinates/sky_coordinate.py", line 811, in apply_space_motion
icrsvel.d_lon.to_value(u.radian / u.yr),
AttributeError: 'SphericalCosLatDifferential' object has no attribute 'd_lon'. Did you mean: '_d_lon'?
The SC still clearly has a velocity (proper motion) in the longitudinal direction, despite the error message.
