Hello, I’ve run into an issue with Astropy causing test failures for us. I’m not sure if this is expected behavior / something I’m doing wrong, but when converting between geocentic and geodetic EarthLocation coordinates, I don’t always get the same answer when converting from one reference frame to the other and back again.
Here’s a small self-contained example:
import random
from astropy.coordinates import EarthLocation
def try_roundtrip():
rand = lambda: random.random() * 10e6
before = EarthLocation.from_geocentric(
x=rand(), y=rand(), z=rand(), unit="m"
geodetic = before.to_geodetic()
after = EarthLocation.from_geodetic(
lat=geodetic.lat,
lon=geodetic.lon,
height=geodetic.height,
assert before == after, (
f"initial value {before} doesn't match conversion round-trip value {after}"
try_roundtrip()
The assertion fails for me often, but not every single time. This is on an Ubuntu 24.04 workstation in Python 3.12 using Astropy 7.1.1.
The numbers I get back are close, but not exactly the same. I’m assuming there’s some floating point rounding happening internally somewhere. Is there any way to guarantee stable output in tests, or do I need to add pytest.approx() and live with it?
