the Sunpy version is 3.1.5
the aiapy version is 0.6.3
The images I am using have been downloaded with Fido and saved in a folder in my PC, they are full disk level 1 AIA images
The script is:
base_raw=sunpy.map.Map(basemap_file)
base_updated_pointing= update_pointing(base_raw)
base_registered = register(base_updated_pointing)
basemap= normalize_exposure(base_registered)
new_dimensions = [2048, 2048] * u.pixel
basemap = basemap.resample(new_dimensions)
The error log is:
ValueError Traceback (most recent call last)
Input In [6], in <cell line: 18>()
31 base_updated_pointing= update_pointing(base_raw)
32 # print(base_updated_pointing.data.shape)
33 # print(base_updated_pointing.meta)
34 # base_observer_fixed= fix_observer_location(base_raw)
—> 35 base_registered = register(base_updated_pointing)
36 print(‘\n\n’, base_registered.meta)
38 # plt.figure()
39 # base_registered.plot()
40 # plt.colorbar()
44 # basemap = sunpy.map.Map(base_registered.data/base_registered.exposure_time.to(u.s).value,
45 # base_registered.meta)
File ~\Miniconda\miniconda3\lib\site-packages\aiapy\calibrate\prep.py:80, in register(smap, missing, order, use_scipy)
78 scale_factor = smap.scale[0] / scale
79 missing = smap.min() if missing is None else missing
—> 80 tempmap = smap.rotate(
81 recenter=True,
82 scale=scale_factor.value,
83 order=order,
84 missing=missing,
85 use_scipy=use_scipy
86 )
87 # extract center from padded smap.rotate output
88 # crpix1 and crpix2 will be equal (recenter=True), as prep does not
89 # work with submaps
90 center = np.floor(tempmap.meta[‘crpix1’])
File ~\Miniconda\miniconda3\lib\site-packages\astropy\units\decorators.py:304, in QuantityInput.call..wrapper(*func_args, **func_kwargs)
302 # Call the original function with any equivalencies in force.
303 with add_enabled_equivalencies(self.equivalencies):
→ 304 return_ = wrapped_function(*func_args, **func_kwargs)
306 # Return
307 ra = wrapped_signature.return_annotation
File ~\Miniconda\miniconda3\lib\site-packages\sunpy\map\mapbase.py:1648, in GenericMap.rotate(self, angle, rmatrix, order, scale, recenter, missing, use_scipy)
1645 pixel_center = pixel_array_center
1647 # Apply the rotation to the image data
→ 1648 new_data = affine_transform(new_data.T,
1649 np.asarray(rmatrix),
1650 order=order, scale=scale,
1651 image_center=np.flipud(pixel_center),
1652 recenter=recenter, missing=missing,
1653 use_scipy=use_scipy).T
1655 if recenter:
1656 new_reference_pixel = pixel_array_center
File ~\Miniconda\miniconda3\lib\site-packages\sunpy\image\transform.py:94, in affine_transform(image, rmatrix, order, scale, image_center, recenter, missing, use_scipy)
91 else:
92 rot_center = image_center
—> 94 displacement = np.dot(rmatrix, rot_center)
95 shift = image_center - displacement
96 if not use_scipy:
File <array_function internals>:180, in dot(*args, **kwargs)
File ~\Miniconda\miniconda3\lib\site-packages\astropy\utils\masked\core.py:572, in MaskedNDArray.array_finalize(self, obj)
567 super_array_finalize(obj)
569 if self._mask is None:
570 # Got here after, e.g., a view of another masked class.
571 # Get its mask, or initialize ours.
→ 572 self._set_mask(getattr(obj, ‘_mask’, False))
574 if ‘info’ in obj.dict:
575 self.info = obj.info
File ~\Miniconda\miniconda3\lib\site-packages\astropy\utils\masked\core.py:228, in Masked._set_mask(self, mask, copy)
225 if ma.shape != self.shape:
226 # This will fail (correctly) if not broadcastable.
227 self._mask = np.empty(self.shape, dtype=mask_dtype)
→ 228 self._mask[…] = ma
229 elif ma is mask:
230 # Even if not copying use a view so that shape setting
231 # does not propagate.
232 self._mask = mask.copy() if copy else mask.view()
ValueError: could not broadcast input array from shape (2,2) into shape (2,)
