I have a question about the format of the time passed into obstime in the radial_velocity_correction function (SkyCoord — Astropy v7.0.0)
Looking at the Wright and Eastman paper which is the reference, it seems like times should be in BJD. But that is not an available format for radial_velocity_correction (JD is allowed, but not HJD or BJD).
Should the time passed into radial_velocity_correction be JD (which means the function performs the conversion to BJD internally), or should the user be converting JD into BJD, and then passing that into obstime?
