Preserving compression quantization on rewrite
I’d like to use Astropy to read one FITS file with some tile-compressed image HDU and write a new one that preserves the original tile-compressed image without quantizing again (but does modify the header, add some other new HDUs, and rewrite some other HDUs more substantially).
I was hoping just reading a CompImageHDU from one file and then appending to a different HDUList object that was opened with mode=’append’ on the other file would do this, but it looks more like it’s decompressing the image data and then compressing it again (which results in changes, I think because ZZERO and ZSCALE values inferred from the never-quantized data are different from those inferred from the quantized-one data).
Is there some other way to extract the original compressed data and pass it around in memory to be used again on write, or (even better, because it’s cheaper) preserve the ZZERO and ZSCALE values so they can be used again the next time?
Did you try with disable_image_compression=True ? With this option you can get the compressed data as a BinTableHDUso when appending it would directly copy the compressed tiles.
Yes, that’s what I ended up going with. Unfortunately it means I had to read the file twice, because I couldn’t figure out how to go from the disable_image_compress=True BinTableHDU to a CompImageHDU (the constructor for the latter seems like it ought to work, but it didn’t for reasons I don’t quite recall and can’t really go back and check now).
It should be doable with CompImageHDU(bintable=hdu):
That doesn’t work for me on its own; I saw that code in the Astropy source, too, but it looks like something is different between the state of the BinTableHDU there and what I get from a indexing the HDUList returned by astropy.io.fits.open(filename, disable_image_compression=True).
Here’s the traceback I get:
../../../install/conda/envs/lsst-scipipe-12.1.0/lib/python3.13/site-packages/astropy/io/fits/hdu/compressed/compressed.py:494: in data
    data = self.section[...]
../../../install/conda/envs/lsst-scipipe-12.1.0/lib/python3.13/site-packages/astropy/io/fits/hdu/compressed/section.py:61: in __getitem__
    data = decompress_image_data_section(
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
compressed_data = FITS_rec([([128, 0, 0, ..., 65, 84, 176], 0.95107269, 2.04241298e+09),
          ([128, 0, 0, ..., 153, 212, 106], 0.9...04241299e+09)],
         dtype=(numpy.record, [('COMPRESSED_DATA', '>i4', (2,)), ('ZSCALE', '>f8'), ('ZZERO', '>f8')]))
compression_type = 'RICE_1'
compressed_header = XTENSION= 'BINTABLE'           / binary table extension
BITPIX  =                    8 / 8-bi...
UZSCALE =    0.951072692871094
bintable = <astropy.io.fits.hdu.table.BinTableHDU object at 0x7cecebbd3cb0>
image_header = XTENSION= 'IMAGE   '
BITPIX  =                  -32 / data...
first_tile_index = array([0, 0]), last_tile_index = array([4, 3])
    def decompress_image_data_section(
        compressed_data,
        compression_type,
        compressed_header,
        bintable,
        image_header,
        first_tile_index,
        last_tile_index,
        Decompress the data in a `~astropy.io.fits.CompImageHDU`.
        Parameters
        compressed_data : `~astropy.io.fits.FITS_rec`
            The compressed data
        compression_type : str
            The compression algorithm
        compressed_header : `~astropy.io.fits.Header`
            The header of the compressed binary table
        bintable : `~astropy.io.fits.BinTableHDU`
            The binary table HDU, used to access the raw heap data
        first_tile_index : iterable
            The indices of the first tile to decompress along each dimension
        last_tile_index : iterable
            The indices of the last tile to decompress along each dimension
        Returns
        data : `numpy.ndarray`
            The decompressed data array.
        compressed_coldefs = compressed_data._coldefs
        _check_compressed_header(compressed_header)
        tile_shape = _tile_shape(compressed_header)
        data_shape = _data_shape(compressed_header)
        first_array_index = first_tile_index * tile_shape
        last_array_index = (last_tile_index + 1) * tile_shape
        last_array_index = np.minimum(data_shape, last_array_index)
        buffer_shape = tuple((last_array_index - first_array_index).astype(int))
        image_data = np.empty(
            buffer_shape, dtype=BITPIX2DTYPE[compressed_header["ZBITPIX"]]
        quantized = "ZSCALE" in compressed_data.dtype.names
        if image_data.size == 0:
            return image_data
        settings = _header_to_settings(compressed_header)
        zbitpix = compressed_header["ZBITPIX"]
        dither_method = DITHER_METHODS[compressed_header.get("ZQUANTIZ", "NO_DITHER")]
        dither_seed = compressed_header.get("ZDITHER0", 0)
        # NOTE: in the following and below we convert the column to a Numpy array
        # for performance reasons, as accessing rows from a FITS_rec column is
        # otherwise slow.
        compressed_data_column = np.array(compressed_data["COMPRESSED_DATA"])
        compressed_data_dtype = _column_dtype(compressed_coldefs, "COMPRESSED_DATA")
        if "ZBLANK" in compressed_coldefs.dtype.names:
            zblank_column = np.array(compressed_data["ZBLANK"])
        else:
            zblank_column = None
        if "ZSCALE" in compressed_coldefs.dtype.names:
            zscale_column = np.array(compressed_data["ZSCALE"])
        else:
            zscale_column = None
        if "ZZERO" in compressed_coldefs.dtype.names:
            zzero_column = np.array(compressed_data["ZZERO"])
        else:
            zzero_column = None
        zblank_header = compressed_header.get("ZBLANK", image_header.get("BLANK", None))
        gzip_compressed_data_column = None
        gzip_compressed_data_dtype = None
        # If all the data is requested, read in all the heap.
        if tuple(buffer_shape) == tuple(data_shape):
            heap_cache = bintable._get_raw_data(
                compressed_header["PCOUNT"],
                np.uint8,
                bintable._data_offset + bintable._theap,
        else:
            heap_cache = None
        for row_index, tile_slices in _iter_array_tiles(
            data_shape, tile_shape, first_tile_index, last_tile_index
            # For tiles near the edge, the tile shape from the header might not be
            # correct so we have to pass the shape manually.
            actual_tile_shape = image_data[tile_slices].shape
            settings = _update_tile_settings(settings, compression_type, actual_tile_shape)
            if compressed_data_column[row_index][0] == 0:
                if gzip_compressed_data_column is None:
                    gzip_compressed_data_column = np.array(
                        compressed_data["GZIP_COMPRESSED_DATA"]
                    gzip_compressed_data_dtype = _column_dtype(
                        compressed_coldefs, "GZIP_COMPRESSED_DATA"
                # When quantizing floating point data, sometimes the data will not
                # quantize efficiently. In these cases the raw floating point data can
                # be losslessly GZIP compressed and stored in the `GZIP_COMPRESSED_DATA`
                # column.
                cdata = _get_data_from_heap(
                    bintable,
                    *gzip_compressed_data_column[row_index],
                    gzip_compressed_data_dtype,
                    heap_cache=heap_cache,
                tile_buffer = _decompress_tile(cdata, algorithm="GZIP_1")
                tile_data = _finalize_array(
                    tile_buffer,
                    bitpix=zbitpix,
                    tile_shape=actual_tile_shape,
                    algorithm="GZIP_1",
                    lossless=True,
            else:
                    bintable,
                    *compressed_data_column[row_index],
E               TypeError: _get_data_from_heap() got multiple values for argument 'heap_cache'
(edited because the first traceback I posted was due to user error). This one is from doing:
with astropy.io.fits.open(filename, disable_image_compression=True) as hdu_list:
    image_hdu: ExtensionHDU = hdu_list[1]
    if isinstance(image_hdu, astropy.io.fits.BinTableHDU):
        image_hdu = astropy.io.fits.CompImageHDU(bintable=image_hdu)
    image_hdu.data
It works with the example files from astropy so maybe something specific to the compression parameters in your file. If you can share an example file, I would be happy to have a look.
Sorry for the long delay, it took me a while to find time to dig into this again. I’ve now narrowed it down quite a bit. The problem only occurs if the BinTableHDU data is accessed before trying to make a CompImageHDU:
import sys
import astropy.io.fits
def fail(filename: str):
        table_hdu = hdu_list[1]
        if True:  # Switch this to False to make this function succeed.
            print(table_hdu.data.dtype)
        image_hdu = astropy.io.fits.CompImageHDU(bintable=table_hdu)
        print(image_hdu.data.shape)
if __name__ == "__main__":
    fail(sys.argv[1])
This reproduces the failure on some of the Astropy example images, including comp.fits, though I actually get a slightly different error message on my image:
  File "/home/jbosch/LSST/install/conda/envs/lsst-scipipe-12.1.0/lib/python3.13/site-packages/astropy/io/fits/hdu/compressed/_tiled_compression.py", line 417, in decompress_image_data_section
        bintable,
    ...<2 lines>...
On the Astropy example images I get KeyError: “Key ‘GZIP_COMPRESSED_DATA’ does not exist.”.
I can try to find a place to post my image that if it’s useful, but I suspect it’s actually the same underlying problem and fixing it on the example images will fix my case, too.
The good news is that everything appears to work if I access the CompImageHDU.data first and only then go back and access BinTableHDU.data, and that works fine for my application.
Ah, nevermind about the order-of-operations workaround; it looks like accessing the compressed image data first somehow consumes the heap data, so if I then try to write out the BinTableHDU, I get: OSError: Could not find heap data for the ‘COMPRESSED_DATA’ variable-length array column.
Ok, I think I understand where the problem comes from:
  • CompImageHDU assumes that it manages the heap on its own, without relying on BinTableHDU to load tiles from the heap. So when its accesses the table rows it expects to find the indexes in the heap. As long as the table data is not accessed this is true.
  • But once the table is accessed, BinTableHDU replaces the heap indexes by the actual data from the heap. For comp.fits it then fails because one of the rows starts with a 0 which trigger the GZIP case but I can imagine that it will fail later/differently for another file.
Not sure if this would be easy to fix (probably needs a different way to handle the heap) but maybe worth reporting this use case (which is specific but seems something interesting to support) and discuss this with the other FITS maintainers/authors.
Thanks. I’ll go make an issue and link this thread. At some point I might even have time to dive in and submit a fix, but that’s probably a few months away at least; for now I can just live with reading the file twice.
