AttributeError: module 'sunpy.net.attrs' has no attribute 'cdaweb'
I am running the example code to retrieve the CDAWeb data
from sunpy.net import Fido
from sunpy.net import attrs as a
from sunpy.timeseries import TimeSeries
trange = a.Time(‘2021/07/01’, ‘2021/07/08’)
dataset = a.cdaweb.Dataset(‘SOLO_L2_MAG-RTN-NORMAL-1-MINUTE’)
result = Fido.search(trange, dataset)
print(result)
but it returns an attribute error stating that:
AttributeError Traceback (most recent call last)
in ()
1 trange = a.Time(‘2021/07/01’, ‘2021/07/08’)
----> 2 dataset = a.cdaweb.Dataset(‘SOLO_L2_MAG-RTN-NORMAL-1-MINUTE’)
3 result = Fido.search(trange, dataset)
4 print(result)
AttributeError: module ‘sunpy.net.attrs’ has no attribute ‘cdaweb’
Has anybody experienced the same error?
Hello!
Could you tell me what version of sunpy you are running?
Using sunpy.__version__
Thanks!
Hello! Thank you for your reply
I was using Sunpy 2.0, but then I noticed that sunpy.net.attrs.cdaweb works on the latest version.
I then updated it to Sunpy 4.0.5 and it is now working perfectly.
Thanks
