Speeding up Atropy calculations
I’m attempting to use astropy to calculate the solar & lunar illumination over a sequence of regularly spaced intervals. My code seems to work, but it seems pretty slow - I’m calculating both values every 15 minutes over 30 days and the lunar calculations take around 10 seconds, while the solar calculations take around 24s.
Is there anything I can do to speed things up? I should note, I’m just a software guy - I have no experience in astronomy and/or astropy so feel free to explain the astronomy side to me like I’m a child! Full code below:
from astropy.coordinates import get_body, get_sun, EarthLocation, AltAz
from astropy.time import Time, TimeDelta
from astropy.coordinates import solar_system_ephemeris
from datetime import datetime, timezone
import time as tm
def calculate_solar_millilux(time, location) -> float:
    Calculates solar illuminance in millilux.
    # 1. Define Location and Time
    loc = location
    # 2. Get Sun position (Alt/Az)
    sun_altaz = get_sun(time).transform_to(AltAz(obstime=time, location=loc))
    elevation = sun_altaz.alt.deg
    # 3. Model: Illuminance based on elevation
    # This is a simplified model (e.g., Kasten & Young or empirical approximation)
    if elevation <= 0:
        return 0.0, elevation  # Sun is below horizon
    # Approximate solar illuminance (lux) as a function of elevation (degrees)
    # At zenith (90 deg), direct sun is ~100,000 - 130,000 lux
    # Formula approximation for bright day:
    lux = 130000 * np.sin(np.radians(elevation)) * (1 - 0.1 * np.exp(-elevation/10))
    # Convert to millilux
    millilux = lux * 1000
    return millilux, elevation
def calculate_lunar_illumination(time, location):
    # Get moon position
    with solar_system_ephemeris.set('builtin'):
        moon = get_body('moon', time, location)
        altaz = AltAz(obstime=time, location=location)
        moon_altaz = moon.transform_to(altaz)
        # Calculate phase (0.0 to 1.0)
        # 1.0 is full moon, 0.0 is new moon
        sun = get_sun(time)
        elongation = moon.separation(sun, origin_mismatch="ignore")
        phase = (1 - np.cos(elongation)) / 2.0
    # Illumination calculation (approximate formula)
    # Full moon zenith illumination ≈ 300-400 millilux (mlx)
    max_lux = 350 # millilux at zenith
    altitude_deg = moon_altaz.alt.deg
    # If moon is below horizon, illumination is 0
    if altitude_deg < 0:
        millilux = 0.0
    else:
        # Basic correction for altitude (sin(altitude))
        # Note: Atmospheric extinction not fully modeled here
        millilux = max_lux * phase * np.sin(np.radians(altitude_deg))
    return millilux, altitude_deg, phase
if __name__ == "__main__":
    # Set location (observer)
    location = EarthLocation(lat=42.28, lon=-83.74, height=250) # Example: Ann Arbor, MI
    today = datetime.combine(datetime.today(), datetime.min.time(), tzinfo=timezone.utc)
    time = Time(today)
    interval_minutes = 15
    numDays = 30
    times = [time + TimeDelta(interval_minutes * i * u.minute) for i in range(0, numDays*24*60//interval_minutes)]
    print(f"Calculating illuminance for {location} starting at {today.isoformat()} (UTC)")
    print(f"  {len(times)} points ({numDays} days at {interval_minutes} minute intervals)")
    print(f"  --------------------------------------------------------------------------")
    solar_illuminations = []
    lunar_illuminations = []
    start_time = tm.perf_counter()
    for t in times:
        sol_illum, sol_elev = calculate_solar_millilux(t, location)
        solar_illuminations.append((t, sol_illum))
    end_time = tm.perf_counter()
    elapsed_time = end_time - start_time
    print(f"  Calculated solar illuminance for {len(times)} time points in {elapsed_time:.6f} seconds.")
    for t in times:
        lunar_illum, lunar_alt, lunar_phase = calculate_lunar_illumination(t, location)
        lunar_illuminations.append((t, lunar_illum))
    print(f"  Calculated illuminance for {len(times)} time points in {elapsed_time:.6f} seconds.")
