Hello everyone, I just joined this forum
I’ve started working with SunPy to study solar prominences with both H-alpha data and SDO/AIA imaging, and later also SO data. I’m trying to firstly compare H-apha and AIA193A images to locate the prominences but I’m having problems with axis and projection.
It’s being very comfortable to work with AIA data, as it can be turned into a map object with sunpy.map but I can’t do the same for GONG data, so I’m treating it as a standard fits file. This is what I’m doing:
hdul = fits.open(fileHa)
wcs = WCS(hdul[1].header)
image_data = fits.getdata(fileHa)
map193 = sunpy.map.Map(file193)
fig = plt.figure(figsize=(12,4))
ax1 = fig.add_subplot(121, projection=map193)
im1 = map193.plot(axes=ax1)
ax2 = fig.add_subplot(122, projection=wcs)
im2 = ax2.imshow(image_data, cmap='hot')
ax2.grid(alpha=0.5, color='white', lw=0.5)
ax2.title.set_text('H-Alpha ' + hdul[1].header['DATE-OBS'].replace('T', ' '))
fig.colorbar(im2, orientation='vertical')
plt.colorbar()
The issue is that, as you can see, while AIA193 image has helioprojective coordinates, GONG has its own coordinates, and I don’t know how to reproject it so they both have the same. I’ve tried changing the ‘CTYPE’ value but it just blows up the axes. If anyone knows how to do it, or how to turn the GONG data into a sunpy.map object, that would ease the job.
Thank you in advance!
