Apologies for my obvious incompetence, but I have updated to the latest versions of satrapy, ancillary packages, and reproject - the latter of which I want to run a FITS ARC → SIN projection. Running the example from the reproject pages, I am unable to import reproject_interp, for example
(base) xyz255@RKBYODMLGW1-2 python % python3 reproject.py
Traceback (most recent call last):
File “reproject.py”, line 4, in
from reproject import reproject_interp
File “/Users/xyz255/astrodata/W3_DATA//python/reproject.py”, line 4, in
ImportError: cannot import name ‘reproject_interp’ from ‘reproject’ (/Users/xyz255/astrodata/W3_DATA/python/reproject.py)
This came up running the image reproduction example from: Image reprojection (resampling) — reproject v0.7.1
The code is run under python3.7 like this:
from astropy.wcs import WCS
from astropy.utils.data import get_pkg_data_filename
hdu1 = fits.open(get_pkg_data_filename(‘galactic_center/gc_2mass_k.fits’))[0]
hdu2 = fits.open(get_pkg_data_filename(‘galactic_center/gc_msx_e.fits’))[0]
ax1 = plt.subplot(1,2,1, projection=WCS(hdu1.header))
ax1.imshow(hdu1.data, origin=‘lower’, vmin=-100., vmax=2000.)
ax1.coords[‘ra’].set_axislabel(‘Right Ascension’)
ax1.coords[‘dec’].set_axislabel(‘Declination’)
ax1.set_title(‘2MASS K-band’)
ax2 = plt.subplot(1,2,2, projection=WCS(hdu2.header))
ax2.imshow(hdu2.data, origin=‘lower’, vmin=-2.e-4, vmax=5.e-4)
ax2.coords[‘glon’].set_axislabel(‘Galactic Longitude’)
ax2.coords[‘glat’].set_axislabel(‘Galactic Latitude’)
ax2.coords[‘glat’].set_axislabel_position(‘r’)
ax2.coords[‘glat’].set_ticklabel_position(‘r’)
ax2.set_title(‘MSX band E’)
array, footprint = reproject_interp(hdu2, hdu1.header)
fits.writeto(‘msx_on_2mass_header.fits’, array, hdu1.header, overwrite=True)
And works up to the import command from reproject towards the end.
The run platform is macOS Monterey 12.1, and I have lots of other python libraries working perfectly well.
Can anyone please help on what seems to be a config issue at my end?
Many thanks
