smaret
September 29, 2021, 3:59pm
1
I find the WCSAxes framework extremely useful for making maps in celestial coordinates (e.g. RA and Dec.). However, I sometime need to make maps in relative coordinates instead (that is RA and Dec spherical offsets with respect to given position).
How can I do this with WCSAxes?
Thanks,
Sébastien
Perhaps you could define a new coordinate system centred on the current target, and use that in your plots?
smaret
September 30, 2021, 8:09am
3
Thanks for your answer. In practice, how do you define this news coordinate system?
Cadair
October 5, 2021, 12:34pm
4
Hey @smaret
If you create yourself a SkyOffsetFrame and then generate an overlay using that frame (Overlaying coordinate systems — Astropy v4.3.1 ) you should achieve what you want.
Let us know how it goes, and maybe provide a picture of the result
smaret
June 29, 2022, 12:21pm
5
Thanks for your answer @Cadair , and sorry for the long silence.
I was able to make a map in relative coordinates as you suggested:
fig = plt.figure(0, clear=True)
w = astropy.wcs.WCS(hdu.header)
ax = fig.add_subplot(1, 1, 1, projection=w)
# Remove the absolute coordinates
ra = ax.coords["ra"]
dec = ax.coords["dec"]
ra.set_ticks_visible(False)
ra.set_ticklabel_visible(False)
dec.set_ticks_visible(False)
dec.set_ticklabel_visible(False)
ra.set_axislabel("")
dec.set_axislabel("")
# Create an overlay with relative coordinates
aframe = continuum_peak.skyoffset_frame()
overlay = ax.get_coords_overlay(aframe)
ra_offset = overlay["lon"]
dec_offset = overlay["lat"]
ra_offset.set_axislabel("RA offset")
dec_offset.set_axislabel("Dec offset")
ra_offset.set_major_formatter("s.s")
dec_offset.set_major_formatter("s.s")
ra_offset.set_ticks_position("bt")
ra_offset.set_ticklabel_position("b")
dec_offset.set_ticks_position("lr")
dec_offset.set_ticklabel_position("l")
ra_offset.set_axislabel_position("b")
dec_offset.set_axislabel_position("l")
ra_offset.coord_wrap = 180 # avoid wrapping
