I’m trying to download only the FUV level 1 IRIS data using the JSOC interface.
It’s pretty easy to generate a response that contains all the data (SJI, NUV, FUV) using the following code:
response = sunpy.net.Fido.search(
sunpy.net.attrs.Time("2014-01-01T00:00", "2014-01-01T00:05"),
sunpy.net.attrs.jsoc.Series("iris.lev1"),
sunpy.net.attrs.jsoc.Notify("roytsmart@gmail.com")
response
Which outputs:
<sunpy.net.fido_factory.UnifiedResponse object at 0x0000016B0036D8D0>
Results from 1 Provider:
22 Results from the JSOCClient:
Source: http://jsoc.stanford.edu
TELESCOP INSTRUME
IRIS NUV
IRIS FUV
IRIS SJI
IRIS NUV
IRIS SJI
IRIS NUV
IRIS SJI
IRIS NUV
IRIS FUV
IRIS SJI
IRIS NUV
IRIS FUV
IRIS NUV
IRIS FUV
IRIS SJI
IRIS NUV
IRIS FUV
IRIS SJI
IRIS NUV
IRIS FUV
IRIS SJI
IRIS NUV
However, when I try to use the following code which I felt should work:
sunpy.net.attrs.jsoc.Notify("roytsmart@gmail.com"),
sunpy.net.attrs.Instrument("FUV"),
response
I get an error
NoMatchError Traceback (most recent call last)
Cell In[43], line 1
----> 1 response = sunpy.net.Fido.search(
2 sunpy.net.attrs.Time("2014-01-01T00:00", "2014-01-01T00:05"),
3
4 sunpy.net.attrs.jsoc.Series("iris.lev1"),
5 sunpy.net.attrs.jsoc.Notify("roytsmart@gmail.com"),
6 sunpy.net.attrs.Instrument("FUV"),
7 # sunpy.net.attrs.jsoc.Keyword("INSTRUME") == "FUV",
8 )
9 response
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\net\fido_factory.py:315, in UnifiedDownloaderFactory.search(self, *query)
269 """
270 Query for data in form of multiple parameters.
271
312 parts individually.
313 """
314 query = attr.and_(*query)
--> 315 results = query_walker.create(query, self)
317 # If we have searched the VSO but no results were returned, but another
318 # client generated results, we drop the empty VSO results for tidiness.
319 # This is because the VSO _can_handle_query is very broad because we
320 # don't know the full list of supported values we can search for (yet).
321 results = [r for r in results if not isinstance(r, vso.VSOQueryResponseTable) or len(r) > 0]
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\net\attr.py:613, in AttrWalker.create(self, *args, **kwargs)
609 def create(self, *args, **kwargs):
610 """
611 Call the create function(s) matching the arguments to this method.
612 """
--> 613 return self.createmm(self, *args, **kwargs)
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\util\functools.py:18, in seconddispatch.<locals>.wrapper(*args, **kwargs)
17 def wrapper(*args, **kwargs):
---> 18 return dispatcher.dispatch(args[1].__class__)(*args, **kwargs)
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\net\fido_factory.py:244, in _create_and(walker, query, factory)
242 @query_walker.add_creator(attr.AttrAnd)
243 def _create_and(walker, query, factory):
--> 244 return factory._make_query_to_client(*query.attrs)
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\net\fido_factory.py:478, in UnifiedDownloaderFactory._make_query_to_client(self, *query)
464 def _make_query_to_client(self, *query):
465 """
466 Given a query, look up the client and perform the query.
467
476 Instance of client class
477 """
--> 478 candidate_widget_types = self._check_registered_widgets(*query)
479 results = []
480 for client in candidate_widget_types:
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\net\fido_factory.py:460, in UnifiedDownloaderFactory._check_registered_widgets(self, *args)
457 n_matches = len(candidate_widget_types)
458 if n_matches == 0:
459 # There is no default client
--> 460 raise NoMatchError("This query was not understood by any clients. Did you miss an OR?")
462 return candidate_widget_types
NoMatchError: This query was not understood by any clients. Did you miss an OR?
And when I used a slightly different code that was also suggested by the docs:
# sunpy.net.attrs.Instrument("FUV"),
response
I get a different error that is hard to understand
DrmsQueryError Traceback (most recent call last)
Cell In[44], line 1
3 sunpy.net.attrs.jsoc.Series("iris.lev1"),
4 sunpy.net.attrs.jsoc.Notify("roytsmart@gmail.com"),
5 # sunpy.net.attrs.Instrument("FUV"),
6 sunpy.net.attrs.jsoc.Keyword("INSTRUME") == "FUV",
7 )
8 response
269 """
271
313 """
610 """
612 """
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\net\fido_factory.py:486, in UnifiedDownloaderFactory._make_query_to_client(self, *query)
484 if isinstance(tmpclient, vso.VSOClient):
485 kwargs = dict(response_format="table")
--> 486 results.append(tmpclient.search(*query, **kwargs))
488 # This method is called by `search` and the results are fed into a
489 # UnifiedResponse object.
490 return results
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\net\jsoc\jsoc.py:307, in JSOCClient.search(self, *query, **kwargs)
305 # Update blocks with deep copy of iargs because in _make_recordset we use .pop() on element from iargs
306 blocks.append(copy.deepcopy(iargs))
--> 307 return_results = astropy.table.vstack([return_results, self._lookup_records(iargs)])
308 return_results.query_args = blocks
309 return_results._original_num_rows = len(return_results)
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\sunpy\net\jsoc\jsoc.py:768, in JSOCClient._lookup_records(self, iargs)
766 log.debug(f"Running following query: {ds}")
767 log.debug(f"Requesting following keywords: {key}")
--> 768 result = client.query(ds, key=key, rec_index=isMeta)
769 if result is None or result.empty:
770 return astropy.table.Table()
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\drms\client.py:1061, in Client.query(self, ds, key, seg, link, convert_numeric, skip_conversion, pkeys, rec_index, n)
1059 status = lres.get("status")
1060 if status != 0:
-> 1061 self._raise_query_error(lres)
1063 res = []
1064 if key is not None:
File ~\AppData\Local\Programs\Python\Python311\Lib\site-packages\drms\client.py:669, in Client._raise_query_error(d, status)
667 msg = "DRMS Query failed."
668 msg += f" [status={status}]"
--> 669 raise DrmsQueryError(msg)
DrmsQueryError: query failed: ERROR: column "fuv" does not exist at character 3328
Error at /home/jsoc/cvs/Development/waystation/JSOC-orig/base/libs/db/db_postgresql.c, line 451: Query 'SELECT T1.recnum, T1.sunum, T1.slotnum, T1.sessionid, T1.sessionns, T1.cparms_sg000, T1.image_lev1_bzero, T1.image_lev1_bscale, T1.bld_vers, T1.date, T1.date__obs, T1.t_obs, T1.imgfpt, T1.fsn, T1.isysn, T1.fid, T1.instrume, T1.img_path, T1.img_type, T1.camera, T1.sumsptrl, T1.sumspat, T1.exptime, T1.expsdev, T1.int_time, T1.quality, T1.quallev0, T1.cropid, T1.lutid, T1.totvals, T1.datavals, T1.missvals, T1.percentd, T1.datamin, T1.datamax, T1.datamedn, T1.datamean, T1.datarms, T1.dataskew, T1.datakurt, T1.datap01, T1.datap10, T1.datap25, T1.datap75, T1.datap90, T1.datap95, T1.datap98, T1.datap99, T1.nsatpix, T1.iicrsid, T1.crs_desc, T1.crs_type, T1.crs_nreg, T1.win_flip, T1.tsr1, T1.ter1, T1.tsc1, T1.tec1, T1.tsr2, T1.ter2, T1.tsc2, T1.tec2, T1.tsr3, T1.ter3, T1.tsc3, T1.tec3, T1.tsr4, T1.ter4, T1.tsc4, T1.tec4, T1.tsr5, T1.ter5, T1.tsc5, T1.tec5, T1.tsr6, T1.ter6, T1.tsc6, T1.tec6, T1.tsr7, T1.ter7, T1.tsc7, T1.tec7, T1.tsr8, T1.ter8, T1.tsc8, T1.tec8, T1.wcsdbver, T1.wcsaxes, T1.xcen, T1.ycen, T1.crpix1, T1.crpix2, T1.crval1, T1.crval2, T1.crval3, T1.cdelt1, T1.cdelt2, T1.cdelt3, T1.ctype1, T1.ctype2, T1.ctype3, T1.cunit1, T1.cunit2, T1.cunit3, T1.pc1_1, T1.pc1_2, T1.pc2_1, T1.pc2_2, T1.pc3_1, T1.pc3_2, T1.crpix1a, T1.crpix2a, T1.crval1a, T1.crval2a, T1.crval3a, T1.cdelt1a, T1.cdelt2a, T1.cdelt3a, T1.ctype1a, T1.ctype2a, T1.ctype3a, T1.cunit1a, T1.cunit2a, T1.cunit3a, T1.pc1_1a, T1.pc1_2a, T1.pc2_1a, T1.pc2_2a, T1.pc3_1a, T1.pc3_2a, T1.pointrec, T1.time_qbi, T1.aeulrbrx, T1.aeulrbry, T1.aeulrbrz, T1.acg_roll, T1.ophase, T1.sat_rot, T1.flat_rec, T1.orb_rec, T1.rsun_obs, T1.dsun_obs, T1.geix_obs, T1.geiy_obs, T1.geiz_obs, T1.heix_obs, T1.heiy_obs, T1.heiz_obs, T1.obs_vr, T1.hlz, T1.saa, T1.temp_rec, T1.itf1ccd1, T1.itf2ccd2, T1.itnuccd3, T1.itsjccd4, T1.bt06cbpx, T1.bt07cbnx, T1.bt15ieb, T1.it08gtwm, T1.it14sppx, T1.it16spnx, T1.ispsname, T1.isppktim, T1.isppktvn, T1.isqisysn, T1.isqfsn, T1.iifrmtyp, T1.iiobslid, T1.iifrmlid, T1.isqoltid, T1.isqfltid, T1.iifdbid, T1.iifuvfdb, T1.iinuvfdb, T1.iisjifdb, T1.iiolrpt, T1.iiolnrpt, T1.iiflrpt, T1.iiflnrpt, T1.isqoltdx, T1.isqoltnx, T1.isqfltdx, T1.isqfltnx, T1.iissloop, T1.iissdiod, T1.iissoffr, T1.iiss_src, T1.iissctrl, T1.ifmcpos, T1.ifmpos, T1.ifwctgt, T1.ifwenc, T1.ifwpos, T1.iwm1cpos, T1.iwm1ctgt, T1.iwm1enc, T1.iwm2cpos, T1.iwm2ctgt, T1.iwm2enc, T1.iimgshce, T1.iimgcfd1, T1.iimgcfd2, T1.iimgcfd3, T1.iimgcfd4, T1.ifuvcexp, T1.inuvcexp, T1.isjicexp, T1.iimgots, T1.isqorbpd, T1.isqorbse, T1.isqorbsu, T1.isqowtid, T1.isqsrtid, T1.isqpzta, T1.isqpztb, T1.isqpztc, T1.iisspzta, T1.iisspztb, T1.iisspztc, T1.irtpzta, T1.irtpztb, T1.irtpztc, T1.iwbpzta, T1.iwbpztb, T1.iwbpztc, T1.isxer, T1.isxeravg, T1.isxermax, T1.isxermin, T1.isyer, T1.isyeravg, T1.isyermax, T1.isyermin, T1.igtpoffx, T1.igtpoffy, T1.igtpsvx, T1.igtpsvy, T1.itacssts, T1.iaectid, T1.iaecenam, T1.iaecevfl, T1.iaecflag, T1.iaecflfl, T1.iaecltim, T1.iaecevlt, T1.iihis1, T1.iihis2, T1.iihis3, T1.iihis4, T1.iihis5, T1.iihisfsn, T1.history, T1.comment, T1.sg_000_file, T1.sg_000_axis000, T1.sg_000_axis001 FROM iris.lev1 AS T1, (SELECT q2.max1 AS max FROM (SELECT max(recnum) AS max1, min(q1.max) AS max2 FROM iris.lev1, (SELECT iris.lev1.T_OBS, iris.lev1.FSN, max(recnum) FROM iris.lev1 WHERE ( ( 1167609635.000000<=T_OBS AND T_OBS<=1167609935.000000 ) ) AND ( INSTRUME=FUV ) GROUP BY iris.lev1.T_OBS, iris.lev1.FSN) AS q1 WHERE iris.lev1.T_OBS = q1.T_OBS AND iris.lev1.FSN = q1.FSN GROUP BY iris.lev1.T_OBS, iris.lev1.FSN) AS q2 WHERE max1 = max2) AS q3 WHERE T1.recnum = q3.max ORDER BY T1.T_OBS, T1.FSN LIMIT 75000' failed.
Failed in drms_retrieve_records, query = 'SELECT T1.recnum, T1.sunum, T1.slotnum, T1.sessionid, T1.sessionns, T1.cparms_sg000, T1.image_lev1_bzero, T1.image_lev1_bscale, T1.bld_vers, T1.date, T1.date__obs, T1.t_obs, T1.imgfpt, T1.fsn, T1.isysn, T1.fid, T1.instrume, T1.img_path, T1.img_type, T1.camera, T1.sumsptrl, T1.sumspat, T1.exptime, T1.expsdev, T1.int_time, T1.quality, T1.quallev0, T1.cropid, T1.lutid, T1.totvals, T1.datavals, T1.missvals, T1.percentd, T1.datamin, T1.datamax, T1.datamedn, T1.datamean, T1.datarms, T1.dataskew, T1.datakurt, T1.datap01, T1.datap10, T1.datap25, T1.datap75, T1.datap90, T1.datap95, T1.datap98, T1.datap99, T1.nsatpix, T1.iicrsid, T1.crs_desc, T1.crs_type, T1.crs_nreg, T1.win_flip, T1.tsr1, T1.ter1, T1.tsc1, T1.tec1, T1.tsr2, T1.ter2, T1.tsc2, T1.tec2, T1.tsr3, T1.ter3, T1.tsc3, T1.tec3, T1.tsr4, T1.ter4, T1.tsc4, T1.tec4, T1.tsr5, T1.ter5, T1.tsc5, T1.tec5, T1.tsr6, T1.ter6, T1.tsc6, T1.tec6, T1.tsr7, T1.ter7, T1.tsc7, T1.tec7, T1.tsr8, T1.ter8, T1.tsc8, T1.tec8, T1.wcsdbver, T1.wcsaxes, T1.xcen, T1.ycen, T1.crpix1, T1.crpix2, T1.crval1, T1.crval2, T1.crval3, T1.cdelt1, T1.cdelt2, T1.cdelt3, T1.ctype1, T1.ctype2, T1.ctype3, T1.cunit1, T1.cunit2, T1.cunit3, T1.pc1_1, T1.pc1_2, T1.pc2_1, T1.pc2_2, T1.pc3_1, T1.pc3_2, T1.crpix1a, T1.crpix2a, T1.crval1a, T1.crval2a, T1.crval3a, T1.cdelt1a, T1.cdelt2a, T1.cdelt3a, T1.ctype1a, T1.ctype2a, T1.ctype3a, T1.cunit1a, T1.cunit2a, T1.cunit3a, T1.pc1_1a, T1.pc1_2a, T1.pc2_1a, T1.pc2_2a, T1.pc3_1a, T1.pc3_2a, T1.pointrec, T1.time_qbi, T1.aeulrbrx, T1.aeulrbry, T1.aeulrbrz, T1.acg_roll, T1.ophase, T1.sat_rot, T1.flat_rec, T1.orb_rec, T1.rsun_obs, T1.dsun_obs, T1.geix_obs, T1.geiy_obs, T1.geiz_obs, T1.heix_obs, T1.heiy_obs, T1.heiz_obs, T1.obs_vr, T1.hlz, T1.saa, T1.temp_rec, T1.itf1ccd1, T1.itf2ccd2, T1.itnuccd3, T1.itsjccd4, T1.bt06cbpx, T1.bt07cbnx, T1.bt15ieb, T1.it08gtwm, T1.it14sppx, T1.it16spnx, T1.ispsname, T1.isppktim, T1.isppktvn, T1.isqisysn, T1.isqfsn, T1.iifrmtyp, T1.iiobslid, T1.iifrmlid, T1.isqoltid, T1.isqfltid, T1.iifdbid, T1.iifuvfdb, T1.iinuvfdb, T1.iisjifdb, T1.iiolrpt, T1.iiolnrpt, T1.iiflrpt, T1.iiflnrpt, T1.isqoltdx, T1.isqoltnx, T1.isqfltdx, T1.isqfltnx, T1.iissloop, T1.iissdiod, T1.iissoffr, T1.iiss_src, T1.iissctrl, T1.ifmcpos, T1.ifmpos, T1.ifwctgt, T1.ifwenc, T1.ifwpos, T1.iwm1cpos, T1.iwm1ctgt, T1.iwm1enc, T1.iwm2cpos, T1.iwm2ctgt, T1.iwm2enc, T1.iimgshce, T1.iimgcfd1, T1.iimgcfd2, T1.iimgcfd3, T1.iimgcfd4, T1.ifuvcexp, T1.inuvcexp, T1.isjicexp, T1.iimgots, T1.isqorbpd, T1.isqorbse, T1.isqorbsu, T1.isqowtid, T1.isqsrtid, T1.isqpzta, T1.isqpztb, T1.isqpztc, T1.iisspzta, T1.iisspztb, T1.iisspztc, T1.irtpzta, T1.irtpztb, T1.irtpztc, T1.iwbpzta, T1.iwbpztb, T1.iwbpztc, T1.isxer, T1.isxeravg, T1.isxermax, T1.isxermin, T1.isyer, T1.isyeravg, T1.isyermax, T1.isyermin, T1.igtpoffx, T1.igtpoffy, T1.igtpsvx, T1.igtpsvy, T1.itacssts, T1.iaectid, T1.iaecenam, T1.iaecevfl, T1.iaecflag, T1.iaecflfl, T1.iaecltim, T1.iaecevlt, T1.iihis1, T1.iihis2, T1.iihis3, T1.iihis4, T1.iihis5, T1.iihisfsn, T1.history, T1.comment, T1.sg_000_file, T1.sg_000_axis000, T1.sg_000_axis001 FROM iris.lev1 AS T1, (SELECT q2.max1 AS max FROM (SELECT max(recnum) AS max1, min(q1.max) AS max2 FROM iris.lev1, (SELECT iris.lev1.T_OBS, iris.lev1.FSN, max(recnum) FROM iris.lev1 WHERE ( ( 1167609635.000000<=T_OBS AND T_OBS<=1167609935.000000 ) ) AND ( INSTRUME=FUV ) GROUP BY iris.lev1.T_OBS, iris.lev1.FSN) AS q1 WHERE iris.lev1.T_OBS = q1.T_OBS AND iris.lev1.FSN = q1.FSN GROUP BY iris.lev1.T_OBS, iris.lev1.FSN) AS q2 WHERE max1 = max2) AS q3 WHERE T1.recnum = q3.max ORDER BY T1.T_OBS, T1.FSN LIMIT 75000'
[status=6]
Does anyone know where I might be going wrong?
